im Axle Specialists
Old 23-06-2017   #16
Re: Grande Punto Grinding/Rubbing When Accelerating
Thanks Bernie. The thing that confuses me is I had the driveshaft replaced only 6 months ago so why will it have gone again? Will I be able to remove the driveshaft and fit a new bearing? Or will I need to get a whole new driveshaft? I'd much rather pay 15 for a good bearing and get my hands dirty than pay hundreds for an OEM shaft.
sirr0m17 is offline Reply With Quote Quote
Old 26-06-2017   #17
Became old and sensible
MrDerv's Avatar
MrDerv has donated!
Quote Originally Posted by sirr0m17 View Post
Never discount the fact it could have been a faulty new bearing In which case, should have been warrantied for 12 months if fitted from a garage. Worth checking with whoever fitted it to see if they can inspect it and let you know if it needs doing or not.
Current Garage
Mine: 2008 BMW 120d Coupe Stage 2 Mapped
Hers: 2007 Renault Megane 1.6 VVT Auto Dynamique
MrDerv is offline Reply With Quote Quote
Old 26-06-2017   #18
Yes brickfoot I think you're right because I've realised a few more things over the weekend. The grinding is NOT engine speed related it's road speed related. Having listened to where the noise is coming from I am now convinced it is the inner driveshaft support bearing (under the driver footwell). I will take it back to the garage I had change it and seek their opinion. Thanks again
Likes MrDerv liked this post
Old 20-11-2019   #19
Greece
Sorry to bring back a dead thread but did you get this figured out? I'm having the same exact problem, had a mechanic check it and he told me that 3 out of the 4 transmission bearings were busted or in really bad shape. Though, I am somewhat reluctant it was the transmission since the same grinding noise was produced even in neutral... any ideas?
Insanity is offline Reply With Quote Quote
Old 20-11-2019   #20
Belgium
Quote Originally Posted by Insanity View Post
the entire transmission rotates even in neutral as soon as the vehicule is moving ...
BRs Bernie
(T) 2010 Qubo - Grinding sound when accelerating Jasper205 Fiorino (Mk3) 5 04-01-2015 20:39
(T) slight grinding noise when accelerating 1st gear? Cento900 Cinquecento / Seicento 2 10-04-2014 14:34
(T) grinding rubbing sound from engine? kath2 Punto (Mk2/2b) 12 10-08-2013 00:31
(T) Grinding/Rubbing noise whilst driving :/ Help!! thaduck1 Punto (Mk2/2b) 13 28-03-2013 19:55
(T) grinding/rubbing noise Front RHS Kev_marea Marea 2 30-08-2007 08:25
