Please can someone assist me, i currently have cloth seats and intend on installing leather. I have the new seats and as far as I can see the drivers seat does not have the wire for the seat belt not worn. They have the usual bolster wear but by swooping the seat bases which are easy to remove you end up with the bolsters that have never been sat across on the out side, I expected both to have the wire hanging out the bottom. I assume they work by weight on the seat closing a normally open contact, therefore the system expects the seat belt to be plugged in and it turns off the light/alarm. If that's the case then if the seat contacts remain normally open permanently then it would never expect the seat belt to be put on and there would be no issues. I have MES and have used it to silence the alarm as it annoyed me that if your passenger took to long to put the belt on then the noise was quite piercing. The strangest thing is why only the passenger seat has the connection I would very much like someone to enlighten me as to why that is, thank you
