You will need to remove AIRBAG.. safety precautions required..
Remove steering wheel.
Remove 5 torx screws on casing .
You will now probably see the broken wire..
Solder wires together. You may need to further seperate the stalk to find the break
Refit in reverse of removal.
Take care to sit stalks in appropriate recess locating holes
