Bernievarian
Prominent member
- Jan 15, 2017
- 2,993
- 654
Hi Mattyo,
should have told us, you probably have your wastegate not opening, generating an overboost situation that pops-up the P0234 and put the engine in safe (limp) mode.
Verify all (small) pipings near the turbo:
- there is a 3 way valve controled by the ECU
- when boost is too high, this valve opens the wastegate with turbo's high pressure output
- when boost back to normal, the valve return the pressure from wastegate actuator to turbo's low pressure inlet
- a broken or disconnected pipe will cause the wastegate not opening, thus overboosting
- a bad menbrane in the actuator would have the same effect
- a seized wastegate also ...
- and finally, an obstructed pipe aswell ...
Regards, Bernie
Regards, Bernie
