Hello guys,
I had a problem with my battery over the winter that lead me to change my battery twice. All started after my miles on the dashboard start flashing and my blue and me completly stoped working. So I went to FIAT and had the car checked but they couldn't find anything wrong with the battery and the only thing that they believe it can be is the convergence unit failure that was resulting to my battery drain. However, they couldn't check if the convergence unit had a failure (or causing the drain) because their equipment for that check did not work. So I tried to find online, and asked some other FIAT delearship and they all told me that I have a failure with my convergence unit but they said that this may not be the problem for the battery issue. Anyway, I still talked with one of the dealearships and managed to get a good deal to remove my convergence unit and add a new stereo to the car which at least my radio will work and if the convergence unit was the problem for the barrety issue then it will be fixed. However, I still have one problem, the miles are still flashing. Do you know why is that and how it can be fixed? I think when I gave the car to FIAT they did a proxy alligment update, because I asked them to do that as well, and probably didnt fix the problem. If you have any idea of how to stop the miles flashing please let me know, also if you had a similar problem let me know how you dealt with it and if everything is ok with your car.
As I am a new member please let me know if this topic has been discusses before.
