Just took my little car to the mechanics due to misfiring, did a compression test turns out 2 of the 4 cylinders are below the normal pressure be quoted 300-500 to fix I am considering just getting a used engine off ebay, What I would like to know if the engine codes matter? aslong as its the same 1.2 engine from a punto.
My engine code is 199A4000 so would i be able to use a 199A2000 engine?
I found a cheap one on ebay all working for £75 looks identical to my engine but its from a 2007 1.2? if the engine code is different will it not fit?
Many Thanks
Many Thanks
