souljasingh
- Feb 28, 2017
- 5
- 1
Hello guys, heard about the forum from a friend. I have recently got a fiat grande punto 2009 plate 1.4 16v and was changing the pads the other day and noticed that there was some gear oil leaking from the square plate that goes around the inner cv joint. I've had a research and I believe there is a seal behind this plate however i did notice there is a layer of silicone around the plate so maybe the plate had been off before and was warped so will need replacing.
I'm asking if i am correct in there being an oil seal behind the plate and what would be the process to change this and how would i take the inner cup out that goes into the gearbox as i know these are difficult to take out is there a recommend tool. And would i need to replace the plate in front of the seal as i believe that is where the oil is leaking from.
I found the picture attached below of is the part marked number 4 the seal and refering to the plate i mean number 16.
Thank you for all your help. Im probably going to attempt this thurs or fri and will be picking up a seal tomorrow and plate.
Souljasingh
Souljasingh
