Thread Tools
Old 23-02-2017   #1
Remote Key has no range?
The remote entry key fob was playing up and was only working when directly next to or inside the car, changed the fob battery and no difference, any ideas?
Lewissssd is offline Reply With Quote Quote
Old 23-02-2017   #2
Belgium
Re: Remote Key has no range?
Receiving antenna ?
- located in the left front pinlar (under the plastic fitting ?)
- connected to pins 1 & 2 of the Body computer under the glove box (for right hand driven cars)
- no fuse in the antenna circuit...
Regards, Bernie
Old 23-02-2017   #3
Romania
how old is the car?
for how long do you have it?
when did it start doing this?
aurick86 is offline Reply With Quote Quote
Old 24-02-2017   #4
Quote Originally Posted by aurick86 View Post
how old is the car?
08 Reg, had the car about 8 months and only started doing it a few days ago, worked fine one evening and then wouldn't work in the morning and hasn't worked since then
Old 24-02-2017   #5
Romania
Take the remote apart and clean the chip with some izopropil alcohol.
Check for any cold solder joints:
example 1
example 2
example 3
And reflow the solder.
I've fixed a similar problem on the remote key for a Opel Vectra.
Likes Bernievarian liked this post
Old 24-02-2017   #6
Trader Rating: 1
portland_bill has donated!
As above.
But also, consider the battery. Just because it is new, does not mean it is fresh. Did it come from a source that sells plenty? check the expiry date on the packaging if possible. Old stock may be little better than the one you took out.
13 years motor trade, 16 years motor industry. 14 years Driving Instructor & 7 years Fleet Trainer
Panda Alessi
portland_bill is offline Reply With Quote Quote
Old 28-02-2017   #7
Belgium
Any update ??
Thread Tools
(T) Fiat 500 Remote Key Works But Has No Range ? oldschoolstreak 500 6 02-04-2015 14:48
(T) Looks of remote key in 2006? Would a remote key with red logo work? andy1 Panda 19 23-03-2015 15:38
(T) Stilo JTD Remote key fob range cugetare Stilo 3 01-04-2013 15:39
(T) Short range remote control nelsonrocha Stilo 0 04-02-2005 15:10
(G) Remote Control RANGE pantjo Stilo 24 07-12-2003 02:24
