The remote entry key fob was playing up and was only working when directly next to or inside the car, changed the fob battery and no difference, any ideas?
- located in the left front pinlar (under the plastic fitting ?)
- connected to pins 1 & 2 of the Body computer under the glove box (for right hand driven cars)
- no fuse in the antenna circuit...
08 Reg, had the car about 8 months and only started doing it a few days ago, worked fine one evening and then wouldn't work in the morning and hasn't worked since then
But also, consider the battery. Just because it is new, does not mean it is fresh. Did it come from a source that sells plenty? check the expiry date on the packaging if possible. Old stock may be little better than the one you took out.
