dannyev4ns
- Feb 11, 2017
- 9
- 2
I have a 56 plate punto speaker on right at front broke a while back so I replaced both speakers with some vibe speakers, fitted them and they worked fine, just recently same thing has Happened but this time the speaker is still fine, so it's the wiring, I've had the inside door panel off and had a mess about with wires ( I originally connected through from original wiring with spade connectors to cable for vibe speakers) and can't seem to get my head round it, I had a play with the connector on inside of door that connects wiring, pulled off the rubber cover and the inside was wet! Soggy mush came out but only things not working is speaker and tweeter, at a bit of a loss, can't tell where the cable goes to to the radio as I have a new aftermarket one installed. At a bit of a loss at the moment, don't every think there's an amp???? Any help would be great!!! Oh also if anyone takes inside of door off don't forget to reconnect handle latch!!! Have to wind window down to get door open[emoji23][emoji23][emoji23]
