Hmmm, short trips, engine not warming-up, seems like Aurick already had the answer...
When the engine is cold, the ECU asks for a richer mixture, that will partly deposit on the cold engine surfaces: intake ports in cylinder head and cylinder itself. The final result being a mixture at (or close to) stochïometric ratio.
Side effect is that the petrol deposit partly washes the oil on the cylinder wall and finally drops in the crankshaft housing, giving that petrol smel to the oil but also altering its lubricating properties...
Regarding the thermostat, is the T° stable once the engine is warm ?
Regards, Bernie
ps: Curious to know you fuel consumption ?
If someone helped you fix or understand your issue here, hit the thanks button, it costs nothing
