Hi, I have a Grande punto active 1.2 8v 57 plate.The car initially started to lack a little power and would cut out approaching junctions. I removed the throttle body and cleaned it and the breather pipe as a little mayo was present in the pipe (none in the engine or coolant). The car ran better but not perfect so I bought a replacement map sensor but the engine did not like this so went back to the original and the car seemed to run fine.
A few days later it cut out completely and will not start. The cam belt water pump and tensioner were replaced 10k (2 years ago) and is still tensioner so I don't think this has slipped. The fuel rail has pressure and the injectors are still squirting fine sprays of fuel. The spark plugs are all sparking with a nice bright spark, they were a little wet but I have been cranking the engine without it starting.
As in have fuel and a spark I'm not sure what to look at next. I have been wondering about the throttle body, when the ignition turns on there is a humming noise as it opens ever so slightly then after a couple of seconds it closes. If you push the accelerator pedal down fully it will open the butterfly, but it closes of its own accord, it cannot be partially opened with the pedal, also once you have pressed the pedal down fully and it has closed there is no further response from the pedal. Is this normal? Also what else could be causing the car not to start?
Thanks in advance.
Mark
Thanks in advance.
Mark
