Hi. Please did you ever manage to fix your blower fault? My daughter has the same problem with her 2012 punto. She has dual climate control type. Everything works except the fan. The led bar display moves when I turn the fan up and down, I can hear the air channels moving when I press the buttons to direct air to feet, windscreen, face. Just the fan doesn’t work.Good Morning,
Yes it is the dual climate control system, I did try and trace the wires that go to the fan but they disappear up behind the dash and the other one that is connected to it is a large harness type that goes back behind the the centre console, I am planning to strip it down again and test the fan itself to see if there is life there, I will let you know thanks
