Ben D Patron member Joined Aug 23, 2015 Messages 479 Points 139 Location Aberdeenshire Dec 19, 2016 #1 Going to change box oil, does anyone know what size keys are required for the drain and filler plugs please? Cheers
OP OP Ben D Patron member Joined Aug 23, 2015 Messages 479 Points 139 Location Aberdeenshire Dec 30, 2016 #2 In case anyone else is looks, 12mm Allen key for filler on front of box. 8mm for drain on side of box.
g8rpi Moderator Staff member Parked in the garage Written a guide Uploaded a resource/download Joined Nov 11, 2013 Messages 4,599 Points 1,167 Location Cambridge Dec 30, 2016 #3 What gearbox is in your car? If it's the M32 6-speed, the plug on the side is NOT the oil level. The M32 needs to be drained and then the correct volume of oil added. If it's not a M32 ignore the above. Last edited: Dec 30, 2016
OP OP Ben D Patron member Joined Aug 23, 2015 Messages 479 Points 139 Location Aberdeenshire Dec 30, 2016 #4 Tjet so 5 speed, definitely not m32. Cheers
