Old 22-09-2016   #1
Albania
Transmission Fluid
Hello guys. I have a grande punto 1.3D 2006, with 120.000km. The third and fifth gear while driving are hard to shiftt . The transmission fluid i think has never been changed. Is this the problem or is something else. I will appreciate if you reply.
eliohasa is offline Reply With Quote Quote
Old 22-09-2016   #2
Romania
Re: Transmission Fluid
probably the cables need lubing.
aurick86 is offline Reply With Quote Quote
Old 22-09-2016   #3
Albania
can you please be more specific becuase I am not very familiar with car parts.
Old 22-09-2016   #4
Albania
And also, if it was the fluid problem, should it affect all the gears
Old 22-09-2016   #5
flisko has donated!
look below battery for gearbox cables
flisko is offline Reply With Quote Quote
Old 23-09-2016   #6
Albania
Also i have to add that, when the RPM drops than i can shift normally. And also there is no grinding at all, or anyother noise when i try to shift
Old 23-09-2016   #7
Greece
Change gearbox oil and hope for an improvement.
Also try the double clutch method and see if it helps. If the synchronizers are worn then you will feel a huge difference.
cmosfxx is offline Reply With Quote Quote
Old 24-09-2016   #8
Albania
I tried the double clutch method and it didnt work, so i will change the oil and hope for an important because i dont wanna open the transmission
Old 24-09-2016   #9
Greece
Hmm clutch condition? Can you engage reverse without grinding it?
Old 25-09-2016   #10
Romania
Q:
With the engine off can you shift gears faster than with it on?????
If you can then it's more probably a problem with the clutch i.e it's not completely disengaging.
OR you are not pushing the clutch all the way to the floor.
A clutch bleeding might help
Old 25-09-2016   #11
Albania
The gears shift fine when the car is off, the problem is only when the car is moving. I saw 2 mechanics yesterday. One saif that it was a transmission problem. The other one said that it might be the oil. So i changed it and the problem persists. None of them said it was a clutch problem
Old 25-09-2016   #12
Romania
You never know exactly what it is until you open up the gearbox, my guess would be that the bearings are at fault.
Snails is offline Reply With Quote Quote
Old 25-09-2016   #13
DGPunto has donated!
What oil did you use? Shop4parts does the original stuff: https://www.shop4parts.co.uk/?name=s...2401&sku=40673
DGPunto is offline Reply With Quote Quote
Old 25-09-2016   #14
Romania
the cables might need a slight adjustment.
But if you say it shift better with the engine off i advise you to consider the clutch slave or mater cylinder.
I don't know the exact configuration on your car but i would start looking there.
Old 26-09-2016   #15
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Check the shifter cables bet one is frayed or almost broken internally
https://www.fiatforum.com/grande-pun...lp-please.html
To find them get a mate to shift the gears and look down below the battery you will see them moving
Massive gash
Just a little touch up
(T) Automatic Transmission Fluid - Is This Ok To Use ? fixmypunto Punto (Mk2/2b) 8 14-07-2019 13:03
(T) transmission fluid blackpool Panda (Classic) 4 21-04-2011 23:33
(T) Transmission fluid, how to top up? trig999 Multipla 5 23-08-2009 09:15
(T) Transmission fluid and differential fluid flare 124 Spider (Classic) 3 18-03-2009 15:32
(G) Transmission Fluid 04 2.0 JTD markduncan100 Ulysse 0 16-02-2009 18:39
