Old 14-09-2016   #1
55 plate 1.3 90 wont rev past 2500/3000 rpm
hi all this is my first post although have been a viewer for quite some time and find this site really helpful!
im having problems with my 55 plate grande punto 1.3 90 6speed, after being stood for 12 months, now giving it to my brother (1st car) it will not rev past 2500/3000 and is really slow to accelerate. having looked at some similar posts they have given me an insight but still cant solve the problem! any help would be useful and really appreciated as im losing my mind over it lol!
no codes are showing up on the dash, but i have plugged it in and a stored code came up with a maf sesnor, after disconnecting the problem still persists. not knowing how long the code had been there for ive replaced the sensor with still no joy.
i have then checked all the boost pipes and no splits or holes so there not leaking and also bypassed the intercooler and seems to be fine.
before it wass off the road i changed the egr valve so dont think thats the problem and also disconnected the control unit on the egr and drove it will still no change.
ive checked the arm on the waste gate and it seems to be moving fine and have checked for any play in the turbo and tht seems to be fine too.
at first i just thought it needed an Italian tune as it has been stood so long and not really been drove apart from moving it around the driveway. but still no joy and coming to my wits end with it lol, its a shame really becasu i really love the car and have had many fiats (when there working lol)
any advice would be greatly appreciated thanks in advance
Ryan g is offline Reply With Quote Quote
Old 14-09-2016   #2
Became old and sensible
MrDerv's Avatar
MrDerv has donated!
Re: 55 plate 1.3 90 wont rev past 2500/3000 rpm
If it's been stood for a year, i'd replace the fuel filter and stick some fresh fuel in the tank. Chances are it's being starved of fuel.
Current Garage
Mine: 2013 VW Passat Sport BlueMotion Tech 2.0 TDI Stage 2 Mapped
Hers: 2007 Renault Megane 1.6 VVT Auto Dynamique
MrDerv is offline Reply With Quote Quote
Old 14-09-2016   #3
Hi thanks for the quick reply! Sorry forgot to mention I serviced it before taking for its mot last week did the fuel filter and new fuel as I thought that might be the problem. ( still passed it mot though even though it's not running right lol)
Old 14-09-2016   #4
MrDerv's Avatar
MrDerv has donated!
One last ditch attempt at the MAF then, if you can remove it, give it a clean. The Alfa forum seem to suggest this and it resolves the issue. If it does, the likelyhood is you'll need to replace the MAF shortly after as cleaning it doesn't fix the problem 100%
Current Garage
Old 14-09-2016   #5
My original thought was maf sensor but unplugging still makes no difference, so then I replaced it with a new unit from ces ( quite expensive for some reason lol )and still the problem exists ! The only other idea I have is that there is an exsahust blockage causing back pressure but that's a stab in the dark so to speak
Old 14-09-2016   #6
flisko has donated!
any lights on dash?
flisko is offline Reply With Quote Quote
Old 14-09-2016   #7
Nothing at all! It's why I'm so confused haha
Old 14-09-2016   #8
flisko has donated!
someone had similar problem but it was on a petrol car, it was fuel pump at the end
Old 14-09-2016   #9
Fuel pump I'll have to investigate, could be as the Car had been stood with the same fuel in for 12 months, I'll keep you posted!
Old 14-09-2016   #10
Romania
did you check the air filter?
Snails is offline Reply With Quote Quote
Old 14-09-2016   #11
cheers for the reply
Yeah thought there might be blockage but I've checked it and it looks fine if anything it looks new.
Old 15-09-2016   #12
Fuel pressure regulator valve?
markymark123 is offline Reply With Quote Quote
Old 15-09-2016   #13
I'll check it, wouldn't know where to look? In the engine bay ? It is it down by the tank?
(T) Punto 1.2 -02 Wont rev past 2500 rpm jmaki Punto (Mk2/2b) 10 21-01-2014 22:27
(G) Stilo JTD 115, no power under 2500/3000 RPM uktrucker Stilo 17 24-08-2013 16:09
(G) Wont rev past 2500 rpm!!! spirito de runto Punto (Mk2/2b) 8 09-04-2010 15:19
1.3 Multijet engine, wont rev past 3000 derby allen Lets Talk FIAT 12 01-01-2009 17:35
(T) HGT wont rev above 3000 rpm rema-d Bravo / Brava 6 09-01-2008 13:04
