FIAT Auto Specialist Team
Old 12-09-2016   #1
Spain
Does anyone know where the starter located ? GP T-Jet.
Sorry for my english, im spanish
My starter is dead, and before i change it, i want to clean it and see if i can repair it.
Anyone knows?
Xphectro is offline Reply With Quote Quote
Old 13-09-2016   #2
flisko has donated!
Re: Does anyone know where the starter located ? GP T-Jet.
without a car lift its gonna be hard
flisko is offline Reply With Quote Quote
Old 13-09-2016   #3
Spain
Is it located on gearbox?
Old 13-09-2016   #4
Greece
Quote Originally Posted by Xphectro View Post
Behind the engine under the intake - flywheel side. Hard to remove...very limited space.
cmosfxx is offline Reply With Quote Quote
Old 13-09-2016   #5
Spain
There?
Old 13-09-2016   #6
Greece
Under all that. Follow the red cable from the battery.
Impossible to remove without a lift.
Old 13-09-2016   #7
flisko has donated!
i removed starter without lift few times, drove on concrete blocks and crawled under, it takes time
Old 14-09-2016   #8
Romania
you can remove the starter from under the car (put it on jack stands)
There is only one 13mm screw that needs to be extracted from above, it goes through the bell housing and screws into the starter. You might need to remove the battery.
OH and remove the battery so you don't short out while removing the starter cables ( there are 2: one 10mm and one 13mm)
aurick86 is offline Reply With Quote Quote
Old 15-09-2016   #9
Spain
Thank you!
(G) 2006 Doblo 1.9 m-jet not starting (starter glow plug) abble Doblo 8 26-08-2016 16:57
(T) Punto Mk2 will not starter - starter motor issue? macbrew Punto (Mk2/2b) 9 31-03-2014 20:40
(T) Sensor located above starter motor? Fiat Punto 1996 KTM990 Punto (Mk1) 12 21-02-2014 17:38
(G) Where is it located ? barachello2000 Punto (Mk2/2b) 5 13-12-2007 18:19
(T) Does anyone know where this valve is located filz123 Punto (Mk2/2b) 4 21-06-2007 21:07
