you can remove the starter from under the car (put it on jack stands)
There is only one 13mm screw that needs to be extracted from above, it goes through the bell housing and screws into the starter. You might need to remove the battery.
OH and remove the battery so you don't short out while removing the starter cables ( there are 2: one 10mm and one 13mm)
