FIAT Auto Specialist Team
Old 12-09-2016   #1
Fiat punto grade 1.4 sounds really bad
Hi there, I've changed the sparks, leads, and coil pack now my engine either won't start or when it does sounds uneven stinks of petrol and vibrates violently(sounds like a diesel). I'm really at odds what's happened what I've done wrong and how to fix it. I drive a fiat punto grande 1.4 2009
Qwerty91q is offline Reply With Quote Quote
Old 12-09-2016   #2
Became old and sensible
MrDerv's Avatar
MrDerv has donated!
Re: Fiat punto grade 1.4 sounds really bad
Have you put the plug leads on in the right order from the coils? (i.e., replaced one lead at a time)
Current Garage
Mine: 2008 BMW 120d Coupe Stage 2 Mapped
Hers: 2007 Renault Megane 1.6 VVT Auto Dynamique
MrDerv is offline Reply With Quote Quote
Old 12-09-2016   #3
Stupidly no... the new leads have completely different numbers on them compared to the old ones, but I have been assured they are the correct ones
Old 12-09-2016   #4
Ireland
Quite possibly you've put the wrong leads to the wrong plug. By sounds of things anyways its firing incorrect.
did it fire ok before you changed the leads and coil packs? If no then i'd be looking at how you've plugged in the new leads.
Richard8672 is offline Reply With Quote Quote
Old 12-09-2016   #5
Before the change yes it sounded normal, no vibration etc I've tried every different combination but still can't figure it out
Old 12-09-2016   #6
MrDerv's Avatar
MrDerv has donated!
In which case, you've either put the leads on the wrong plugs from the coil, or you have a faulty coil.
The coil should have a number next to each output, this will be your cylinder number. Cylinder 1 starts at the timing belt side of the engine, and cylinder 4 at the gearbox side.
Ensure you have the leads from the corresponding cylinders to the correct output number on the coil. That should sort you.
Current Garage
Old 12-09-2016   #7
Ireland
you've possibly got the combination wrong so in order of the timing of sparks.
either this or one of the new leads could be faulty. Try using your old leads but you need to have the combination correctly or else it will always misfire
Old 12-09-2016   #8
Is it literally a guessing game when it comes to the combination or can I find out correct sequence some where? What's the best way about it?
I do hope it's not a faulty new coil lol
Old 12-09-2016   #9
Quote Originally Posted by brickfoot View Post
Both old and new coils doesn't have a number on the outputs
Old 12-09-2016   #10
MrDerv's Avatar
MrDerv has donated!
Quote Originally Posted by Qwerty91q View Post
Looking further into it, is the coil mounted to the top of the engine?
If so, the lead order is 1-1, 2-2, 3-3, 4-4. Looking directly
I.e. cylinder 1 lead connects to the first plug hole on the coil, and so on. Work from the timing belt side of the engine first.
Current Garage
Old 12-09-2016   #11
Yes the coil is mounted on the of the engine.
I understand the lead order but the lead numbers I have are
1, 1, 2, 7
Old 12-09-2016   #12
MrDerv's Avatar
MrDerv has donated!
1, 1, 2, 7
Ignore the lead numbers. Just go for connecting cylinder 1 spark plug to output 1 of the coil and so-on.
Current Garage
Old 12-09-2016   #13
Ah got you, I have tried this when I changed the leads and the coil. When the the problem started. Even does it when I reverted to the old coil and leads
Old 12-09-2016   #14
So I've managed to get the car running and it doesn't vibrate violently. It now however sounds like a diesel still and Judders slightly. Is this a misfire?
Old 12-09-2016   #15
MrDerv's Avatar
MrDerv has donated!
Did you disconnect anything else? the VVT solenoid perhaps?
Current Garage
Grande Punto Fiat Grade Punto 1.9 Diesel Multijet luke123321 Members Motors 3 02-08-2012 12:16
(T) Bad clutch sounds yvesthepunto Punto (Mk2/2b) 10 03-03-2011 23:05
(T) my diesel engine sounds really bad, problem!?!? Taulanti Bravo / Brava 0 08-06-2010 18:39
(Tu) Advice on exhaust up grade for 2002 fiat punto kitchman Punto (Mk2/2b) 21 02-03-2010 21:55
A few bad pics of my Sounds Andy J F FIAT Boo Archives 3 19-03-2007 20:58
