Old 11-09-2016   #1
Heater motor loose connection
I had a problem with the fans sleep switch not working so replaced the resistor as that had burnt out. Which temporarily fixed the problem. Now I am having trouble with the wiring that goes to the motor which is close to the resistor. I have to pull the wires up hard to get the motor to work. When I let the wires go the fan speed seems to slow down until it stops. Not good this time of year when I need to de mist the Windows. Any ideas how to solve this problem with the loose connections
welshy0007 is offline Reply With Quote Quote
Old 11-09-2016   #2
Greece
Re: Heater motor loose connection
Unplug the connector and with a small screwdriver try to bend the pins a little.
The plug in the picture is from the resistor cable but I think the plug for the motor is almost the same.
cmosfxx is offline Reply With Quote Quote
(T) Loose connection stestilo7110 Stilo 6 31-08-2014 08:14
(G) Loose connection kevinbarr Stilo 9 09-05-2010 18:02
(T) loose connection on 2.4 anthonytutton Stilo 25 29-09-2007 21:45
loose connection help Anonymous FIAT Boo Archives 5 16-10-2004 20:16
