- Sep 3, 2015
- 31
- 12
So I am thinking of putting a straight pipe on my Mjet from the cat back , can someone tell me if this is legal and will it pass an MOT with one?
In the past I ran a Discovery 300tdi with no boxes at all-straight pipe all the way from the manifold with a side exit behind rear wheel and that went through 3 MOT's with no problems-and it was bloody noisy!
Also ran a Freelander diesel and Polo diesel with straight through pipes as well with no problems.
It will be absolutely fine. With it being a diesel and the fact you're leaving 2 cats in it won't be much louder at all. I have straight through from turbo back and no mot issues whatsoever.
A straight pipe on a petrol however, particularly a naturally aspirated one, is a whole different kettle of fish however.
Still doesn't make it legal
The only thing we can say for certain from this is the MOT tester was not very diligent.
Robert G8RPI.
This was 4 different testers or locations over a 6 year period!
Thinking back I also did the same to a Cavalier 1.7tds about 12yrs ago-that did fail the mot though but not on noise-it was just falling apart!!
Always amazed at the "did you tell your insurance company" quotes, At this rate if you car came new with Michelin tyres and you replaced them with Dunlop would this be classed as a modification! same as different brake pads etc etc! If a vehicle passes a test laid down in law I fail to see the relevance of this. Unless you are asked directly and answer untruthfully, what constitutes a "Modification"?
