Hi all. Im hoping someone can help me with a starting issue on my wifes 1.4 Active Sport.
Its got an intermittent fault which I cant solve and my wife now doesnt want to drive the car with our 10 week old baby in it in case she gets stranded anywhere.
When you turn the ignition key the dash lights all illuminate as they should but the car will not even turn over. It will however bump start very easily and then start perfectly fine for a while again.
My neighbour checked the battery and the output was fine. We also added a booster pack just to be 100% sure it wasnt down to a low charge. I removed the ignition wiring to hotwire the car to rule out a worn ignition barrel but the car still didnt turn over.
I rocked the car in gear to rotate the starter incase of a flat spot to rule that out too. Ive tried the spare key incase of a communication problem, again, nothing.
I also added a booster cable from the battery to the gearbox casing incase of a corroded earth as ive read they can fail, not that either!
Has any one got a diagram of the fuse box please detailing what each relay is for? It may be coincidence but my neighbour gave everything a wiggle and then it started but as we dont know which relay does what then we cant narrow it down.
Any help will be much appreciated!
Wes
Wes
