Hello,
Prior to my last post, it seems the starter motor isn't at fault. Its fiat grande punto 2007 1.3L multi jet diesel. I was at a friends the other night and prior to that night, the car started every time first time with no issues then as I was about to leave, it wouldn't start. I have changed the starter motor but it still won't start. When you turn the key, all the electrics work fine with no issues but when you try to start it, I can here a single click under the bonnet and then silence and nothing happens. I have a warning light of a yellow triangle with an ! Mark inside. The battery has been checked and is fine. I have heard it could be a relay but I don't have a clue with checking them. I don't know where they are located or how to check/change them. Does anyone have anymore information on this issue or how to check the relays?
Thanks in advance,
Kieran
Thanks in advance,
Kieran
