So my first probably serious problem with my GP t-jet from 2008. (Due to lack of serious problems so far, not a frequent active visitor in this section ).
Two weeks ago the car has been at the dealer for a service, one of the things done was brake fluid change (never touched from new before, the car is at 105k km at the moment). Now it seems there is a leak - something drips very slowly (very hard to catch, but there are very visible stains under the car) from the connection between the engine block and gear box bell housing. I used a usb endoscope to peek through the inspection hole in front of the gearbox, but honestly the equipment is so crappy I cannot make any solid judgement from this. I am almost convinced it is the clutch slave cylinder that leaks, but the weirdest thing is that I cannot really notice any drop of the fluid in the reservoir, and by now (I have been observing this for a week) there should be some. Also, the black paint from the protection shield between the box and the block where it leaks peeled of, and that indicates to me it is the brake fluid.
Any ideas or experiences? Could this nevertheless be a coolant leak from some mysterious place (I inspected the vicinity of the thermostat housing, but without taking the engine cover, so that was very limited...). I am right in thinking that replacing the cylinder in case of the c510 box means box out first? Anything else I missed here that I should check?
