I bought this car in November. 2006 model
19k on the clock and was owened by a little old guy who had sadly passed on.
Since day one the car has been had to start from cold.
It spins over ok and fires but then dies almost straight away.
each subsequent attempt to start the car results in it running a little longer but still dying after a few seconds.
After maybe half a dozen attempts it will keep running.
Hot starting is fine.
Only other thing i've noticed is that the temp gauge is moving around erratically,moving up to the top and the red light coming on while i'm trying to start it.
Could these two problems be connected?
I'm wondering if maybe the temp sender is sending false info to the cars brain and it's messing with the fuel/air mixture?
Thank You
Thank You
