Hello!I intend to fit some brembo calipers from agp on my t-jet and I would like some help about fitting.My t-jet has the twin tone 6.5x17 wheels with ET46.The stock abarth has 7x17 ET39 wheels.After some research I found out that the inner clearance is different for 1mm(less inner clearance on my t-jet).Will I really need some spacers on the front in order to fit them or could I skip them?I would really prefer not to use spacers on the front-I have 16mm on the rear though without problem.So what do you think will the brakes be plug and play or should I you the spacers?
