Old 02-02-2016   #1
Singapore
Broken Coolant Pipe!
Hi All!
Weekly checks were fine last two days and today, suddenly engine overheating on the way to work! Air con was misting out and immediately stopped the car. Probably overheated for 30mins or so..?
On the road side, I found out that the coolant pipe leading from engine (right side) directly to the coolant reservoir had came loose!
I believe it will be fine after the pipe is replaced and coolant topped up. But will the 30min engine over heating cause and future issues?
Terenc3Le3 is offline Reply With Quote Quote
Old 02-02-2016   #2
Singapore
This is the video I took when I tried to top up 2L of distilled water. Everything is just flowing out from the broken part on the right of the engine.
Seems not to be the pipe that is broken or burst but the part from the engine where the pipe is being clamped unto broke off.
Any idea what part is that? Thermostat?
Old 02-02-2016   #3
Singapore
Re: Broken Coolant Pipe!
Oh just realised I missed the picture of the broken hose/pipe or part that was broken off..
The other end is attached to the coolant reservoir.
Name:	File 2-2-16, 19 05 46.jpeg
Old 02-02-2016   #4
Yes, that's probably the little plastic spout that screws into the side of the themostat housing. A cheap and nasty solution if ever there was one! It's a relatively easy job. I got a Wahler thermostat (a good make) from Eurocarparts for about £35, I think. It has the same pipe but in metal.
Avocet is offline Reply With Quote Quote
Old 02-02-2016   #5
Greece
Quote Originally Posted by Avocet View Post
No it's not that part.
This is just the hose with the quick release connector.
part no 55703092
cmosfxx is offline Reply With Quote Quote
Old 03-02-2016   #6
I didn't realise that! Can you just buy the plastic spout that screws into the thermostat housing separately then? (Or have I got the wrong end of the stick and it's not actually anywhere near the thermostat housing but is a totally different part)?!
P.S. Sorry, I think I might have just reported that post - I clicked on the wrong link! Hopefully the mods will realise it was just a cock-up!
Old 03-02-2016   #7
Moderator
dombooth is part of the official FF Events Team :)
dombooth has donated!
dombooth is an honorary friend of the forum :)
DiffSpotter 3 - Rooms Champion
You did, don't worry about it.
Current Car: FIAT Bravo 150T Sport
And the mighty Fiat 126!
dombooth is offline Reply With Quote Quote
Old 03-02-2016   #8
Greece
The quick release clip comes with the hose (it's not a separate part)
The other end is on the thermostat and it's metallic (even on the original fiat part)
ID:	164162   Click image for larger version
Name:	fiat thermo.JPG
Old 03-02-2016   #9
Singapore
Hi All. I got mine fixed within £30 with the help of a local workshop. Car's running fine now I guess.. Just worried about the impacts as engine was running overheated with steam coming out from AC vents for about 30mins or less.
Old 03-02-2016   #10
Quote Originally Posted by cmosfxx View Post
That's interesting. Ours was plastic and I assumed it was original, but maybe the car had been fitted with a replacement one at some point?
Old 03-02-2016   #11
Greece
The other one is plastic (the one connected to heater matrix pipes)
Old 04-02-2016   #12
Yes, you're quite right, I was talking rubbish! I've just looked at the old housing (kept it in case I needed a spare temperature sensor) and it was, indeed, the larger diameter plastic spout that had snapped off.
Old 14-01-2020   #13
Just broke this pipe taking an engine out of my fiat 500 the clip end is still attached to the thermostat housing but sounds daft I can’t find where that pipe goes to on the car now the engine is out can any one help thanks
Jamie p74 is offline Reply With Quote Quote
(T) Coolant pipe- help muddy90 Panda 15 20-08-2016 16:55
(T) Coolant pipe adlarplant Ducato 2 02-03-2014 22:29
(T) Coolant pipe has broken ovarb Stilo 7 18-03-2013 18:53
(G) Broken Pipe asaywell Stilo 10 04-02-2007 20:31
(T) coolant pipe bigpigeon2004 Cinquecento / Seicento 7 11-12-2005 17:49
