Hi, my car has an aircon gas leaked and the initial suspect is the evaporator. There are no visible leak around high pressure pipes, low pressure pipes and the condenser.
Compressor is working, blower fan is OK.
Anyone know how to change the evaporator coil, that is behind the dashboard?
DO we need to remove the dashboard in order to access the evaporator? How about steering wheel?
I was told, evaporator coil is usually the prime suspect when there is no visible leak around the system.
thanks
thanks
