- Jul 14, 2015
- 54
- 20
Hi Guys,
First of all apologies as I did create a post about this a while ago, but I have some more information on it now so i'm reposting.
The one issue that plagues my GP is this P0115 engine check light error code. Its a 2006 Grande Punto 8v 1.4. When it comes on it causes the fan to run for a good few minutes very loudly after I turn off the engine; this will happen even if I start the engine from cold and quickly switch it off (it thinks its warmer than it is?).
I purchased this replacement coolant sensor from ebay - http://www.ebay.co.uk/itm/Coolant-Temperature-Sensor-Temp-VE375110-Cambiare-FIAT-ALFA-ROMEO-FORD-VARIOUS-/231743081978?hash=item35f4f6cdfa
fitted it myself and wiped the error code. All seemed well for a few weeks and then it happened again. I wiped it again (ignoring it) and carried on with life, the car runs fine, does long journeys with ease, no overheating issues no drama. But from time to time, usually every 3 weeks or so the engine light will come on at ignition and I will have to plug in my reader and re-erase the P0115 error message. It seems to me to be more prevalent when im trying to start the car in cold conditions (although it isnt limited to that). When the light does come on, when starting in cold conditions, the car is a bit temperamental to keep running to begin with. If I put some revs on it will often splutter and die, though a minute or two left alone running and its fine to drive. Though that is rare, more often than not if the light comes on, she starts up and drives fine, but thought I should mention it.
So now for the extra bit which I havnt shared before. Managed to get some freeze frame data when the error came on earlier this evening, thought some of you guys who are a bit more knowledgable in this area could decipher it for me. Have attached some screen shots, two of the freeze frame data from when the error happened at ignition and one of two sensor readings after a short 10-15 minute journey around town. The weather temperature was around 10 degrees celcius.
I have read around at other peoples posts with the same issue, but I read elsewhere online that rusty coolant may be the cause? Anyone heard anything like that before?
Any help appreciated, cheers guys
EDIT: I should say I have checked the wiring from the sensor best I can (its pretty hard to follow and see) and it all looks intact.
