marc.knuckle
- Nov 12, 2007
- 35
- 11
hi guys.
i have seen a post somewhere on the web that i need to lift the gear gaitor and take an ignition live from the plug under the existing 12v socket.
so far, so good. however, what i will do is get an aftermarket 12v socket and plug the car dashcam plug into this. the aftermarket 12v socket has both black(negative) and red(live) cables. if i connect the red wire to the plug under the gaitor, where would i connect the black?
does that plug under the gaitor have a negative wire also?
cheers
cheers
