- Mar 30, 2008
- 316
- 80
Our Grande Punto has developed a strange fault when starting from cold after a couple days without driving it. It makes a very loud whining sound as if the AC compressor or a pulley/tensioner is seizing up. There's a slight whiff of burning as well, probably from the belt not being able to turn freely. I'm going to try and remove the belt tomorrow and have a look to see whether anything needs replacing.
My question is, if the AC compressor is faulty can you run the car with a shorter belt, connected only to the crank pulley and alternator? That way its still driveable until we can sort the compressor out. I know shorter belts exist as I have a Stilo without AC and with pretty much the same engine and I think they did a 1.2 Grande without AC too???
