Hi, noticed today that the fan on my climate control had stopped working all- together.
So after pulling the fan out and checking the connections I found that one connector in particular is quite badly heat damaged and is the cause of my intermittent connection.
It plugs in to the bottom of the fan assembly and sits right next to the black connector in the picture.
The black one could probably do with replacing as well to be honest but the grey one is the worst and part of the grey housing has crumbled away.
I have had a look at previous threads and they all seem to mention a different connector melting.
So my question is does anyone know where I can get these connector types so I can just splice and attach the new connector???
Cheers for your help in advance.
