PaulGPPunto8v
- Jul 21, 2015
- 10
- 1
Hi I have fitted a new EPS unit from ACS power steering, the unit was a pain to fit but made easier using the walkthrough on here, everything went ok, apart from the clock spring fell to pieces but I have managed to put it all back together and everything on the steering wheel works, so my questions
1. would the clockspring cause the EPS light to come on?
2. My EPS light only comes on when reversing out of a tight space, i.e. a car parking space, what would cause this.
3. when I fitted the unit should the bolts (which are on the swivel part of the eps unit at the back near to where the steering rack connected) be even i.e. the unit exactly central to the two fixing points (bolt holes) if its not could this cause the EPS light to come on, could it be letting the EPS unit flex causing the sensors to think the EPS has gone?
TIA
Paul
TIA
Paul
