Old 08-06-2015   #1
Question Need help with my fiat grande punto
Hello I have a grande pinto with a few problems wondering what to do sell or keep
Its a 1.6td 120bhp or more (0-60 = 7 seconds) no mods that I know of.
So rad is leaking anti freeze and oil, (how to replace please) n.b I know rads do not have oil but its coming from there
Intercooler is bent plus fins damaged, replace with standard asap or get a 65mm deep one
Radio screen is broken dose any one have one they have taken out, I could buy cheap please
Disks and pads need to be replaced shove it in a garage or spend 200 for groved and drilled disks with pads and replace myself I think they fit the 1.4 t-jet
And mods what are the best to do
Many thanks
Tomwingrove is offline Reply With Quote Quote
Old 08-06-2015   #2
FerrariInAffordableTrim
bravo86gaz has donated!
Re: Need help with my fiat grande punto
I would be more worried that antifreeze and oil are mixing, I would be making sure they're leaking from the same place, as for replacing chances it's a bumper off jobby same with the intercooler
Not sure about the brakes from a tjet fitting although I don't see why not, £200 seems a bit steep though
Likes Tomwingrove liked this post
bravo86gaz is offline Reply With Quote Quote
Old 08-06-2015   #3
Could you tell me the best way to check please because I have removed my under tray and I can't see where the leak is coming from because it leaks sometimes but when it leaks its under the rad only oil but my antifreeze go's missing once a week fill it up car never overheats just gets to minimum mark and stays there
And is there a fault with the gearboxes because on changing down to 3rd it likes to pop out off gear doesn't sit right every other gear is fine
200 is steap???? I had a Saxo 1.6 vtr and a 307 xsi (2.0 petrol) and disk and pads for each was 300 so I'm scared off taking this one in because of the cost.
Money is tight in my house I know it is for most but my fiancée can't work due too having knees that dislocate and a broken back
Old 08-06-2015   #4
Oil leak could be from anywhere have you looked in top of engine bay, rocker cover etc,
Antifreeze disappearing could be leaking from a burst hose, the radiator or worse the headgasket
BTW these are only guesses, if I were you I'd get to a garage and get it checked over
Old 08-06-2015   #5
Quote Originally Posted by Tomwingrove View Post
Interesting- I thought the fastest standard GP to 60 was the T-jet which clocked at just under 9. Quick poke online specs the 1.6 multijet at just over 9.5s to 60.
Are you sure no one's had quite a serious fiddle with the engine?
Drove BNW 1.2 Sport, with boot light, ESP and 15" multispokes.
Ordered 15th June 2009, collected 25th September 2009. 10000 miles completed 6th August 2010.
Traded in for Suzuki Swift Sport 10th May 2014.
zanes is offline Reply With Quote Quote
Old 08-06-2015   #6
Hello yeah I'm sure got a video of it and a 0-60 tracker and it happen loads of times not just once there has only been two owners me and a old lady I haven't done anything to this car never needed to and why would an old lady want that sort of power
Old 08-06-2015   #7
Do i need to say more?
Thanks cobalt01 thanked for this post
oXRUSSXo is offline Reply With Quote Quote
Old 11-06-2015   #8
Fiat are known to be conservative as hell with the 0-60 times. Fiat say the T-Jet does 8.9 to 60, but on wet roads and a crap launch I got 8.1. Dry, and with the mods mines now got I reckon low 7's is doable.
New Orleans blue S2 GP T-Jet.
Mods are:
Custom Cat-back with twin tip exit!
Remap soon!
jakepocock is offline Reply With Quote Quote
