I bought a secondhand 1.2 8v grande punto (2008) during November 2014. Last January a series of problems came up as follows :
I noticed moisture in the rear lights and inside the luggage space. A few days later left turn signal went out giving me a blinking warning sound. It turned out that rain water entered both the rear lights and all bulb connections had been corroded. Further more the hose that supplies water to the rear window had also been torn and more water entered the rear side of the car. I had it fixed which means that they replaced the hose, cleaned faulty bulb connections, replaced all the bulbs and i must say that my car as ok for one week when suddenly:
While i was driving I lost power steering (esp warning light came on), abs warning light came on, handbrake light came on, speedometer and rev meter dropped dead to 0. That lasted for 15 or 20 seconds and everything went back to normal except the abs light that was still on. I pulled aside, switched off the car and then back on and everything was good including the abs warning light. Ever since the same pattern repeats 5-6 times a day and lasts for no more than a minute. At the end the abs light stays on until i switch off the engine and turn it back on. Sometimes it gives a break of normal functioning for one week or 10 days but then the problem returns.
Please note that sometimes when I try to switch on the engine after the problem has appeared the key lock warning light also comes on and the engine won't start until i press the clutch pedal!!!! Diagnostic tool gives a can bus error. We have replaced battery, clean the grounding points on the chassis ( I believe there are 3 of them) but no problem solved. Any ideas?
