Hi Everyone,
I am new to this thread and i am here because of the same reason as you ppl are - FIAT love , I have a 'fiat grande punto ' multijet 1.3, diesel, late 2010 model, done 1,3 lakh kilometers.
A couple of months ago, It has started to give black smoke and the pick up has reduced considerably, so i decided to use my 'icarsoft scanner'.
The first time i scanned it gave three error codes which were as follows:
1. P0430 - Catalyst system efficiency below threshhold, bank 2
2. P0139 - 02 sensor circuit slow response Bank 1 sensor 2
3. P0138 - 02 sensor circuit high voltage bank 1 sensor 2.
And since i am not so technical and did not understand what these error codes meant, i searched the net and got that something was wrong in and around Catalyst converter. so i went to a local mechanic who helped me
1.) clean the silencer, by putting pressurized water into the outlet of silencer and as a result ....lot of black carbon came out
2) clean the two sensors , (a)one was just in front of the car near radiator and the (b) second one on the upper side just behind the air filter.
And as a result of these two efforts, pick up has improved considerably and i think a little bit of fuel consumption too has improved, but the black smoke still comes out of the silencer outlet.
So i decided to again use the scanner, which now says no error codes.
Now what could be culprit, ... the sensor, relay for the sensor, or fuse or anything else. Can anyone please help, i know there would be many experts here who are capable of sensing what's wrong. I would be grateful if you could guide me.
Satin.:worship:
Satin.:worship:
