I did think ALL Grandes are interference engines..,
but am happy to be told different.., ;-)
Charlie
Charlie
Charlie
The 1.2 is 65bhp in the grande and is a fire l4 engine (usually non interference). I got told the easiest way finding out if interference is by the oil cap. A screw cap is interference engine and the push rubber cap (like mk2 punto) is non interference
The 1.2 is 65bhp in the grande and is a fire l4 engine (usually non interference be a fire engine type). I got told the easiest way finding out if interference is by the oil cap. A screw cap is interference engine and the push rubber cap (like mk2 punto) is non interference
Puntofan1: by interference he means that if the cam belt snaps it will take out the valves an pistons on the engine (rebuild) and non interference is when the belt snaps but no damage is done to the engine just need new belt unusually an all is good.
"No the evo engine not the eco punto (evo fire engine has screw oil cap older safe fire engines were rubber bung)"
This was taken from https://www.fiatforum.com/showthread.php?t=358596 and Andy Monty was person who said it (knows what he is talking about).
So maybe all gp's are interference (look at oil cap) but I got my belt done when got car with water pump (1.4 8v 2009)
Puntofan01: not sure if you are aware but fiat updated their interval for the cam belt being changed. It's now every 4 years recommended not what states in the book. I went about service plan an they asked me said was only 5 years old (this was last July) said doesn't matter its now every 4 years they recommend cam belt doing :-(
Hope this helps
It is the 60bhp non-interference engine.
The car was towed last night to a independent garage. The top of the engine was removed and unfortunately it appears the engine is seized. It cannot be turned forwards and can just about go backwards with a bar.
Cam belt is attached and apparently not a problem.
The alternator belt turns when trying to start the engine but has not been tested further.
It has been suggested that rather than embarking on a engine rebuild with unknown costs that it would be better to source a new engine.
As I have never been in this situation previously does anyone have a reliable source. He recommended findapart.com and breakeryard.com. There are lots on ebay which come with the inherent risk of ebay! Also could I ask a question that may be deemed stupid? A lot of the engines are listed as either cam or non-cam type or compatible with mk3 or not or ones that are suitable for a mk3 model with or mk3 without aircon. Any help in helping decipher which type of engine to go for would be greatly appreciated! I can't find anything about what mark 2 or 3 my car is in the provided documentation. It does have air con (although it no longer works) for what it is worth.
The car is an 08 1.2l grande punto dynamic 60bhp.
Might be a stupid suggestion but could a failed gearbox cause issues such as this?
Many thanks
Puntofan01: not sure if this is right but looks it
Looks that way yeah. Problem is a belt can go at anytime regardless of age/mileage :-(
