Technical Fiat grande punto sat nav GPS multimedia headunit
Daniely
croydon
Hey guys, just wanted to show you one of my new installs to my grande punto and maybe it could give you some ideas too.
I decided to get rid of the crappy fiat headunit and go for a nice upgraded one however I wanted the original look, so I opted for a headunit that did exactly that
A fiat grande punto designed 6" screen
It has sat nav, equaliser, TV, AV1, AV2 (playstation if you wish)
It has aux, Bluetooth with phonebook function, steering wheel controls set up out of the box, and best of all, a reverse camera.
It looks really good and I've decided to put it on here because I see so many really nicely modified puntos but nothing on the interior.
Got some pictures too ImageUploadedByFIAT Forum1429087254.632777.jpgImageUploadedByFIAT Forum1429087269.184578.jpgImageUploadedByFIAT Forum1429087279.383707.jpgImageUploadedByFIAT Forum1429087349.579153.jpg
I ended up getting it for 180 and fitted it all myself, it's literally plug and play unless your previous owner messed up the wiring, and it's definitely worth it in comparison to the awkward fitting other head units, any questions don't be afraid to ask.
Hi mate, I bought it from aliexpress, if you're interested I can speak to him for you and try and get a good deal, it'll be the best money you've ever spent on this car
That looks bloody marvellous.
If you can, can you post the URL for the unit on AliExpress, or at least the Unit Model ID so I can hit google :D
And finally, how much hassle fitting the reversing camera?
I can't post the link as I have less than 5 posts, so go to Ali express and type in fiat punto, and you'll see it there, the seller name is Sam Mr. And tell him that you were introduced by Daniel, you should be able to get a good deal from there
Reverse camera was literally wiring the video wire under the Trims and to the boot, removed some plastic thing where the reverse wire and tapped into it with the red and black power wires from the reverse camera and all done, it has LEDS which come on at night when I put into reverse mode
Yeah you can connect your sub, it comes with a set of plug in cables for aux, subwoofer, external mic, reverse camera, AV, TV
The additional wire coming out is for the TV antenna
That looks so nice! Is it touch screen? Is it blue & me compatible?
I don't know about blue and me compatability but I know it's plug and play and will probably be better than blue and me
You can use the steering wheel controls found on blue and me for this headunit and it has Bluetooth streaming and phonebook
