Styling Need help with alloy fitment guys
Scotland
I have OZ Racing wheels on at the moment which are 4x100 - 17x7 and there running on 215/40/17. I'm not sure of the offset?
The ones that I'm looking to buy are 4x100, 17x7, ET38, 205/45/17.
The thing that's worrying me is i have brembo's and not sure if they will clear or not, at the moment with a 7mm spacer fitted they just clear by 3-4mm.
So the question is guys would the new wheels clear the brembo's or will i have to find out the offset of the OZ wheels?
Cheers,
PP.
Cheers,
PP.
take your current wheel off and the ET will be printed some where on the back of the alloy (should be anyway)
with you having a 7mm spacers atm you a reducing the ET on your current wheels.
basically. the lower the 'ET' the more your wheels will stick out in the arches.
Thanks guys!
I got them fitted today and they clear by around 2mm if that. :)
Now i have a slight rubbing at rear every time i hit a bump on the road which i'm pretty shocked, thought they would have been fine.
I'm running on 17x7 et38 215/45/17 with eibach springs.
Will i have to go back to sporting springs?
