HELP grande punto 1.9jtd alternator
Jamin420
Anybody know how to take the alternator of a 1.9jtd I would take it to a garage but it has recently taken ally funds with a new clutch dual mass flywheel and new tyres so need to do it myself I have checked the Internet for days with no result or help. Any help would be much appreciated thanks in advance
ask / SEARCH in the GP section, ;)
look at the scuttle drain mod. too, (y)
charlie
Cheers buddy :) i read something about the drainage not being good enough and some guy had found a quick fix will have another look at it. I've tested the terminals on the battery it's putting out between 11-12v
EDIT; ( 1st remove all connections to battery / alternator and clean + retighten - a naff connection will lose volts like that..,)
if it still SOUNDS o.k., :)
remove the brush pack / voltage regulator unit.. with it still on the car;)
as that's what does the output..!!:D
Charlie - Oxford
Charlie - Oxford
Thanks :) i tested my battery again today I
And it was at 12.40v and the other day it was low 11s would the water from the scuttle drain make it do that and now it's drying out the volts are going up and it's starting to work again? Sorry to ask so many questions mate thanks again
Certainly possible;)
have you got the rainwater ducted away from the alternator now..?,
Charlie
Charlie
Not had chance yet I'll have a go at it tomorrow during dinner break at work lol I have a electronic tester at work so I'll check the voltage again tomorrow see if it has risen any
