Thread Tools
Old 20-02-2015   #1
GP 1.2 8v Cambelt / Timing Belt change - without special tools?
Folks,
I'm onto my second Fiat after a few years break, the last one was a 1.4 Brava which got squished when a truck hit it. I've just bought a GP 1.2 and want to change the cam / timing belt & tensioner but can only find guides of how to do this with the special tools for locking the cam & crankshaft. I've various threads here and elsewhere but no certain answers that I could find. This is the first of a few cars that I've changed the cam belt on and it's the first that seems to be only possible with special tools.
Is there a way to do this without those tools?
cancunia is offline Reply With Quote Quote
Old 20-02-2015   #2
Re: GP 1.2 8v Cambelt / Timing Belt change - without special tools?
The reason for the locking tool, is so you don't inadvertently move the crank or cam of of sync when you take the belt off.
I have changed belts in the past without such a tool, however, you'd have to extra due diligence by making your own timing marks, and ensure that they are pretty accurate. A splodge of paint isn't adequate.
Failing that, you can probably manufacture your own locking tool out of a scrag end of old steel etc.
One tooth out on the belt, is unlikely to cause any engine damage, however, the ECU will know about it, so the EML will probably be on there after.
Driving like an idiot and meeting another one coming in the opposite directions has dire consequences.
keat63 is offline Reply With Quote Quote
Old 20-02-2015   #3
Thanks for the quick reply. I like the idea about making some tools up & much better than spending about £80 on tools that you use once for about 30 mins!
From what you've written can I take it that there are no factory made timing marks on either pulley? It seems odd if that's so as it'll be a real challenge to refit a camshaft.
Old 20-02-2015   #4
Moderator
Andy Monty's Avatar
Andy Monty has donated!
No as you loosen top pully off to set tensioner
Old 20-02-2015   #5
Quote Originally Posted by Andy Monty View Post
Sorry, I don't follow what you mean. Apologies if I'm being a bit thick here.
Old 20-02-2015   #6
Moderator
Andy Monty's Avatar
See my guide
Massive gash
Just a little touch up
Old 20-02-2015   #7
See my guide
Andy, I re-read your guide. Am I corect in thinking that the camshaft itself is held in place by the locking tool, but not the camshaft pulley? Does the camshaft position sensor work off the pulley? If so, I can see how moving it relative to the camshaft would require some re-learning.
Old 20-02-2015   #8
Moderator
Andy Monty's Avatar
Yes slacken pully fit locking tool fully loosen pully remove belt rotate loose puly as far clockwise as it goes
Replace belt tensioner and warerpump tension belt lock cam pully back by tightening bolt
Old 20-02-2015   #9
Understood. Thanks
Thread Tools
(T) Timing belt change without special tools? Mozella Grande Punto 7 02-11-2012 14:02
(T) Special tools for cambelt change on T-Jet? Luckor Bravo 5 12-04-2012 13:10
(T) What tools do I need for timing belt / tensioner change? ianlewis Punto (Mk1) 12 22-01-2012 19:05
(T) Special tools for HGT timing belt DaveMcT Punto (Mk2/2b) 2 30-09-2009 12:32
CAMSHAFT LOCKING TOOLS (Haynes Manual) NEEDED FOR TIMING BELT CHANGE.... ON EBAY NOW! dbriglee Auction Watch 0 07-02-2005 09:52
