Old 10-01-2015   #1
08 1.4 starjet grande punto problem!
i recently got a grande punto, the eml is/was on. it would run fine for 50 miles or so then cut out and not rev past 2000, but taking the battery off then on would reset it. then i thought it could be the throttle body so took it off and changed it, it then wouldn't reset at all. the eml code says it is a throttle pedal position sensor. we changed this, didn't help but on removing the old one we took the plug out and plugged it back in and it worked for a few seconds with the eml flickering on and off then it went backed to normal. all of this seems to point to a wiring fault so i started to take the tape off the wiring and it looked fine but when i plugged it back in it never revved at all. this all points to a wiring fault/short circuit/bad earth. but before i strip the loom out is there any common problems? anyone ever had anything like this before?!
mcdaid95 is offline Reply With Quote Quote
(G) grande punto starjet help cubblade11 Grande Punto 4 31-12-2009 12:09
