I need to remove the fuse box on an 08 1.4 8v to check for moisture. The lights are randomly switching (or high and dipped together, I'm not sure) to high beam, without the dashboard indicator. The consensus here seems to be that moisture below the fuse box is the problem.
I have disconnected the battery earth, removed the main 12V feed, but the fuse box seems fixed in. When I pull up it moves perhaps 1mm and appears to hit something. Is there a catch or something that I'm missing?
In the meantime I've removed the main beam fuses and am going to try and see if the dips go out when it flicks or not. Not an ideal situation, so any help would be gratefully received.
