Thread Tools
Old 19-11-2014   #1
Clutch Adjustment - Grande Punto 1.4L 16v Sporting
Hey everyone!
Just wondering if anyone knows how to adjust the clutch/bite on a Grande Punto 1.4L sporting? My bite is really close to the floor and so if the clutch isn't 100% pushed in to the floor I'll crunch specifically 3rd gear and almost always reverse!?
Any help on how to at least have a little look at how to adjust the clutch would be really helpful!
Louis :^D!
Sent from my iPhone using FIAT Forum
Grande Punto 1.4L 16V Sporting
louisvella01 is offline Reply With Quote Quote
Old 20-11-2014   #2
Greece
Re: Clutch Adjustment - Grande Punto 1.4L 16v Sporting
You cannot adjust the clutch bite point.
You HAVE to push the pedal all the way. This is normal.
Is the pedal stiff or very soft ?
(how long do you have the car?)
cmosfxx is offline Reply With Quote Quote
Old 20-11-2014   #3
You would have to push the pedal the whole way, where is the biting point.
I believe the clutch is hydraulic, so if the biting point is low to the floor, then it may need bleeding.
However, if bleeding doesn't cure it, then you could have a weak master or slave cylinder or worse still a lazy pressure plate in which case, it's new clutch time.
Driving like an idiot and meeting another one coming in the opposite directions has dire consequences.
keat63 is offline Reply With Quote Quote
Old 20-11-2014   #4
Worn clutch
Avaxbox is offline Reply With Quote Quote
Old 20-11-2014   #5
DGPunto has donated!
Bleed the clutch hydraulics and/or check for leaks
DGPunto is offline Reply With Quote Quote
Thread Tools
(T) Cinq Sporting clutch adjustment wolvescinq Cinquecento / Seicento 9 02-01-2011 22:50
