im Axle Specialists
Old 14-11-2014   #1
Hammerite rust removal gel
Ay up guys
Just a quick one
Im looking at painting my calipers and drums, they are rusty, pretty thick rust too!
Has anybody used hammerite rust removal gel and if so, does it bring it pretty much back to new metal?
Also....if it took all the rust off so it was back to bare metal, would caliper paint stick to it?
Thanks in advance
jamiet1992 is offline Reply With Quote Quote
Old 14-11-2014   #2
Fiatpuntomk2b has donated!
Re: Hammerite rust removal gel
Quote Originally Posted by jamiet1992 View Post
Ay up guys
Just a quick one
Thanks in advance
Much easier and cheaper to use a wire brush, then follow it up with some sandpaper. Degrease and then paint.
FiatPuntoMK2b
Detailing Freak
Link to Members motors in Signature
Fiatpuntomk2b is offline Reply With Quote Quote
Old 14-11-2014   #3
Does it matter what sandpaper it is? And are you degreasing it with brake cleaner?
Old 15-11-2014   #4
Most rust removal products are convertors which turn iron oxide into iron phosphate which is a white powdery substance which can be easily removed. They also have sealing agents which then protect the treated metal from the air so it won't rust any further, or at least allow you time enough to get some paint on it.
You usually need to wire brush everything first to remove any loose debris then treat.
I'd recommend jenolite as its what most companies use as well as the MOD so it's fairly well respected.
You can do it without rust treatment and most people do but then the paint won't last as well and can flake off.
Maker and voice behind the YouTube channel PuntoHowTo 10k subscribers canít be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is offline Reply With Quote Quote
Old 15-11-2014   #5
Moderator
Peter Pick-Up has donated!
Russia
Wirebrush-brakecleaner-Hammerite satin black=ready.
Peter Pick-Up is offline Reply With Quote Quote
Old 03-12-2014   #6
I used a sanding disc on the drums to bring all the rust off, its looking alot better!
Hammerite just didnt do anything, maybe its just me not using it right but...
Metal is smooth now, very smooth....will i need to wack some primer on them before painting them now?
Mixing Hammerite? Eklipze3k Leisure Lounge 22 11-04-2020 11:34
(T) Deox C Rust Removal Giacosa Panda (Classic) 3 06-11-2014 21:37
(G) Rust removal TangerineTractor Stilo 0 18-07-2012 12:06
Surface rust removal Crazedscot Bodyshop 10 30-08-2007 18:20
