Technical water getting under carpet ??
ame
west midlands
hello all ..getting water under carpet driver side ..although carpet is not wet ?? any idea what could be the cause ?? i've noticed a rectangle plastic piece (drivers right hand side footwell) is also loose, is this supposed to be like this? many thanks
Get a picture of the part.
Make sure it's not clutch fluid.
Yup.
Brake servo plate, it's made out of tissue paper. (or might as well be)
had car checked over ..it's not brake servo plate etc ..water just seems under drivers carpet! no where else is it wet ?? had carpet up & there are no holes or any type of damage!! ..i've got no idea whats going on
Check the drivers door seal and the plastic sheet between the door and the doorcard i.e. the coloured part you touch from inside the car
