Old 02-09-2014   #1
Number plate lights
Hi all i have a 56 plate grande punto. Ive just been out to change the number plate lights to leds but cant get them to work. Will i need to put resistors in to make them work?
birtyb is offline Reply With Quote Quote
Old 02-09-2014   #2
Re: Number plate lights
Could be anything. Could be your actual holders, could be the leds. Im pretty sure the numberplate lights are on the canbus system so they will flag an error, but they should still work.
http://bravo.fiatforum.com/
1.4 8v gp
1.9 td 306
1.2 corsa (x2)
1l micra.
lou5590 is offline Reply With Quote Quote
Old 02-09-2014   #3
Quote Originally Posted by birtyb View Post
Did your bulbs work before?
If so try turning the bulb around
Not saying yoyr stupid but they will only go in one way
Paterson1 is offline Reply With Quote Quote
Old 02-09-2014   #4
LEDs work one way and in mine they wouldn't work without resistors otherwise they just pulsed
Ckem247 is offline Reply With Quote Quote
Old 03-09-2014   #5
Thanks for the reply people the bulbs did work before and when i put the leds in they just flash very dim. So i will try some resistors and see if that makes the leds work instead of a dim flash.
Old 03-09-2014   #6
kyle96 has donated!
normal led's only work one way and need resistors to make them work at all,
'smd' type leds will work (only one way though) but will still throw up an warning light
You need resistors to make the normal led's work, or to stop the warning light for the smd's.
Can get the resistors off ebay for about 6
^First car
Currently own an orange 1.9 mjet sporting
kyle96 is offline Reply With Quote Quote
Old 06-07-2016   #7
CPratt
Carwyn1286's Avatar
Carwyn1286 has donated!
Hi can you tell me what resistors I need so the warning light doesn't display?
Carwyn1286 is offline Reply With Quote Quote
Old 08-07-2016   #8
Italy
Ohm's law is your friend.
Keep in mind in a 5W5 bulb there is a current flow of 0,42A at 14V.
So you've to add a parallel resistor to your LED that dissipates the difference between the current of the LED and 0,42A.
Mind the wattage: a 56 Ohm resistor at 14V dissipates (14*14/56) 3,5W, so you'd have to choice at least a 5W resistor.
For example: if in your LED there is a current of 0,2A you've to add a standard 68Ohm resistor.
Every resistor that dissipates current becomes warm/hot
gioe is offline Reply With Quote Quote
Old 09-07-2016   #9
Greece
I can't see why anyone should install led lights since the system is not made for them?
Yes I would like to have less power consumption (=more power) but no...I have to add resistors to trick the system. (Same consumption with classic bulbs once again)
If you just like the color buy these blue colored bulbs and you're done with all these non compatible LEDs and resistors...
cmosfxx is offline Reply With Quote Quote
Old 09-07-2016   #10
Italy
Imho the only reasons are: they've more lumens and they hardly ever burn out. I've replaced my GP's side-lights so in the daylight I can use them instead of dipped highlights (here you must drive with car's lights always turned on)
Likes cmosfxx liked this post
(G) Number plate lights for a 56 plate Grande punto D8N13L Grande Punto 10 28-05-2014 18:42
(T) Number plate lights Emo Vandriver Scudo 10 22-03-2011 16:33
(S) back number plate with out lights? kevincox1987 Punto (Mk2/2b) 15 15-03-2009 12:25
(T) my number plate lights flash on and off!! charlene homer Punto (Mk1) 4 26-02-2009 15:37
(T) Number plate lights Liam Cinquecento / Seicento 1 23-07-2005 00:51
