louisvella01
Hey all! Me again...
Another little problem has sprung up with my GP 1.4L 16V Sporting... This time its an oil leak. Yay.
I have attached an image which circles where the leak is. It's kinda hard to see the leak on the picture but it should give you a good idea where abouts the leak actually is! It is "deep" in the engine down the side of the Engine block. Right now it's a fairly small leak and has only dripped a little bit but either way, it is still dripping and is all up the side of the engine block. Any leak needs sorting...
Has anyone had a similar leak in the same place before and if so what did you find to be the cause... I have read one or two other peoples posts but none seemed to quite match the problem I'm having... Some where saying it could be a crack in the sump or an O ring etc etc...
Anyway, any help/advice on where to start getting this fixed/plugged up that would be amazing! Thank you all!!
