im Axle Specialists
Old 07-08-2014   #1
Morocco
Unhappy preload wastegate
i want adjust preload wastegate actuator for my car grande Punto 1.3 MJT 75 hp
plz help me
startek2 is offline Reply With Quote Quote
Old 09-08-2014   #2
Cool Re: preload wastegate
hi, are you after more power or has it been incorrectly set? to set wastegate preload you loosen actuator arm securing nut, remove actuator arm securing clip connected to wastegate, set the preload desired and refit in reverse order, although access to the actuator can be difficult in some cars and you may need to remove the turbo
sum1 is offline Reply With Quote Quote
(T) Vl37 wastegate failure :'( timfuller1886 Grande Punto 10 27-02-2014 18:47
(T) Diesel Wastegate Glenny22 Grande Punto 9 02-03-2010 01:36
(T) wastegate chatter ? XXbravoXX Bravo 22 28-08-2009 14:29
(T) Wastegate or Cat? allanhelen Cinquecento / Seicento 17 11-07-2009 16:28
(T) Wastegate chatter arc Cinquecento / Seicento 38 07-11-2005 13:25
