hi, are you after more power or has it been incorrectly set? to set wastegate preload you loosen actuator arm securing nut, remove actuator arm securing clip connected to wastegate, set the preload desired and refit in reverse order, although access to the actuator can be difficult in some cars and you may need to remove the turbo
